Configure the connect-retry period to specify the amount of time, in seconds, between connection attempts for peering sessions. The default is 30 seconds.
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#ip msdp connect—retry 21.0.0.2 40
Variable definitions
The following table defines parameters for the ip msdp connect-retry command.
Variable |
Value |
{A.B.C.D} |
Specifies the MSDP peer IP address. |
<1-65535> |
Specifies the connect-retry interval in seconds. The default is 30 seconds. |
